2007安装中出现的问题
浏览:98431
有些电脑上可以安装并正常使用,可是换了电脑就会出现上面的对话框,
"PROCAST_FLOW_CORE" v2007.0, vendor: pam_lmd
uncounted nodelocked license locked to NOTHING (hostid=ANY) starts: 7-nov-2007, no expiration date
TS_OK: Checkout permitted when client is using terminal client
This license cannot be checked out because:
Feature start date is in the future.
Feature: PROCAST_FLOW_CORE
License path: C:\flexlm\license.dat;
FLEXnet Licensing error:-31,34
For further information, refer to the FLEXnet Licensing End User Guide,
available at " www.macrovision.com".
请问这个应该怎么解决?
