midsurf.pdf
2006-05-07 评论:7 下载:1
下载
大小:1.38MB
抽取中面的培训资料
The inaccurate midsurfaces are midsurf-A
midsurf-B, midsurf-C, midsurf-D and midsurf-E, as indicated in Figure 3.2.
节选段落二:
Reassign targets for midsurf-B
1. From the midsurfaces panel, user edit sub-panel, select assign target.
2. Set the option under pilot point to is opposite.
3. Under surface click the yellow surf button.
midsurf-E
midsurf-D
midsurf-C
midsurf-B
midsurf-A
22 Midsurface Training Altair Engineering
4.
节选段落三:
Correct the targets between points C1 & C1′ , C2 & C2′ , and C3 & C3′ as indicated in
Figure 17 using the same method used for correcting midsurf-B.
Figure 17: Points to be corrected for midsurf-C
24 Midsurface Training Altair Engineering
Correcting targets for midsurf-D
1.
(7条)
<P>好用的东西,,谢了,,</P>
<P>先谢了!</P>
查看更多评论 >
