ANSYS常用命令[超完善中文版].pdf
2021-04-08 评论:3 下载:6
下载
大小:2.38MB
-1:布尔操作失败时产生一个错误信息
如果 Lab=VERSION,其值有:
RV52:激活 5.2 版本兼容性选项;
RV51:激活 5.1 版本兼容性选项;
3.1.2 BTOL, PTOL
Specifies the Boolean operation tolerances.
指定布尔操作的容差
Main Menu>Preprocessor>Modeling>Operate>Booleans>Settings
PTOL :Point coincidence tolerance.
节选段落二:
See the ANSYS Modeling and Meshing Guide for an
illustration. See the BOPTN command for the options available to Boolean operations.
节选段落三:
See the ANSYS
Modeling and Meshing Guide for an illustration. See the BOPTN command for an explanation of
(3条)
不错
赞👍
查看更多评论 >
