Abaqus example inp.pdf
MEEM 5408 Design Automation: Theory and Implementation
ASSIGNMENT 4 - FALL 2004
“Program Integration Using Files”
To create and understand the ABAQUS input file format, you can:
I. Study the “ABAQUS/Standard” manual.
II. Try creating a sample file using the ABAQUS user interface.
III. Study the input file for the problem in Figure 1, which is attached and described
below.节选段落二:
To access the ABAQUS/Standard manual:
1. At a unix prompt, type abaqus –cae.
2. From the user interface menu select Help Getting Started. From here, switch
to the “Getting Started with ABAQUS/Standard: Keywords Version” manual.
3. Close the ABAQUS program to allow others to use it.节选段落三:
To perform the analysis using the input file below (Assignment4.inp), the
program must automatically perform the unix command:
abaqus job=Assignment4 input=Assignment4
To make this system call use the system() function declared in stdlib.h.
below.节选段落二:
