TPASingleReferenc(TPA模块英文帮助)重要.pdf
2014-01-08 下载:45
下载
大小:2.43MB
)...............................................8
Section 1.1.2 LMS Operational TPA or OPAX.....................................................11
Section 1.1.3 Multi-reference Transfer Path Analysis ...........................................15
Section 1.2 TPA Terminology ...........................
节选段落二:
LMS Test.Lab OPAX combines the benefits of the classical TPA with the ones
of the more recent OPA (Operational Path Analysis) technique. A fast overview
of OPA is given to highlight the specificities of LMS Test.Lab OPAX.
节选段落三:
In the
TPA Loads and TPA Results sheet, the operational and FRF display will also be
interpolated to the same X-axis to have an easy alignment of the data. The
original data however will be kept as such.
