MPC与RBE3连接应用.pdf
2018-05-25 下载:49
下载
大小:248.34KB
HyperMesh中通过RBE3单元创建MPC连接说明
MPC RBE3 Connections
HyperMesh Connectors allow you to create MPC’s using RBE3 elements between the nodes of shell-shell,
shell-solid or solid-solid groups by using spot connectors. This FE configuration is currently supported for
Optistruct, Radioss Bulk and Nastran user profiles.
节选段落二:
Existing RBE3 elements in the model will be considered during the realization process to ensure that
the independent nodes of the newly created RBE3 are unique.
• When connecting shells with fine mesh the RBE3 independent nodes will consist of nodes along the
free edge of the component.
• When connecting
节选段落三:
高亮
Administrator
高亮
Administrator
高亮
Solid to Solid
页码,3/3(W)w
2011/12/18file://D:\AltairHW\help\hm\mpc_rbe3_connections.htm
Administrator
高亮
