Bolt_Connection.pdf
2006-04-19 评论:5 下载:258
下载
大小:431.08KB
螺栓连接在我们CAE分析中经常遇到,可能不同情况下,我们会采用不同的方法来处理,下面是一篇关于在CAE仿真中怎样处理螺栓连接的例子,请各位参考。
Bolted Connections
A typical bolted joint (as shown) may contain a washer and gasket to improve the bond, a nut and a bolt
besides the basic structure that it is connecting. The bolt assembly may be pretensioned or it may only
resist shear.
节选段落二:
There are many options involved with a bolted connection. Each option has advantages and
disadvantages, and none of the options will be right for every situation.
节选段落三:
Bolt
Washer
Gasket
Nut
There are many modeling options. None of the
options will produce exactly the behavior of the
connection. The decision of which option to
choose is dependent on required results and time
available to produce results.
(5条)
怎么下载啊
<FONT color=#800080>THANK YOU ^-^</FONT>
查看更多评论 >
