ANSYS 支持的函数列表
2020年2月9日 17:56ANSYS 支持的函数列表,备用与共享,以后不要老再去找了
SIN(X) Sine
COS(X) Cosine
TAN(X) Tangent
ASIN(X) Arcsine
ACOS(X) Arccosine
ATAN(X) Arctangent
ATAN2(Y,X) Arctangent (Y/X) with the sign of each component considered
SINH(X) Hyperbolic sine
COSH(X) Hyperbolic cosine
TANH(X) Hyperbolic tangent
SQRT(X) Square root
ABS(X) Absolute value
SIGN(X,Y) Absolute value of X with sign of Y. Y=0 results in positive sign
NINT(X) Nearest integer
MOD(X,Y) Remainder of X/Y Y=0 returns zero (0)
EXP(X) Exponential
LOG(X) Natural log
LOG10(X) Common log
RAND(X,Y) Random number, where X is the lower bound, and Y is the upper bound
GDIS(X,Y) Random sample of Gaussian distributions, where X is the mean, and Y is the standard deviation
LWCASE(CPARM) Lowercase equivalent of character parameter CPARM
UPCASE(CPARM) Uppercase equivalent of character parameter CPARM
VALCHR(CPARM) Numeric value of character parameter CPARM (If CPARM is a numeric parameter, returns 0.0)
CHRVAL(PARM) Character value of numerical parameter PARM. For ABS(PARM) < 10, character value format is F8.5; for 10 ABS(PARM) < 1000, format is F8.3; for 1,000 ABS(PARM)< 10,000,000, format is F8.0. For 10,000,000 PARM < 100,000,000, format is also F8.0. Otherwise result is 0.0 and is not a character value.
IBSET(b1,n2) Set the n2 bit in value b1 (bits are numbered from 0 to 31)
IBCLR(b1,n2) Clear the n2 bit in value b1
BTEST(b1,n2) Test the n2 bit in value b1 (return true (1.0) if bit is set)
BITAND(b1,b2) Bitwise AND of value b1 and b2
BITOR(b1,b2) Bitwise OR of value b1 and b2
BITXOR(b1,b2) Bitwise XOR of value b1 and b2
BITSET(b1,b2) Set the b2 bits in b1
BITCLEAR(b1,b2) Clear the b2 bits in b1
