岩石锚杆支护(Rock Bolting/bolt Support)数据优化
2021年5月19日 11:471 引言
由于Gensim在上个星期升级到版本4.0.1, 因此需对代码进行重新测试, 已经发现部分代码受到影响, 这个笔记对geotech-words-flashtext-combination进行了测试, 使用了关键词"Rock Bolting/bolt Support", 同时对GeotechSet数据集进行了整体优化.
全长粘结锚杆数值模型(fully grouted cable bolts)
锚杆加固全饱和断裂多孔介质的数值过程 [11/5/2020]
岩石锚固的机理(Physical Mechanisms of Rock Bolting)
2 数据集优化
优化后的数据保存在
{3DEC},
{Cable Bolting},
{Rock Slope},
{Rock bolting},
{fully grouted bolts},
{Engineering rock mass classification}
以及目录X:\Geotech\Rock Mechanics\rockbolting中.
3 文献聚合
[1] Ground Support Using Cable Bolts in Hard Rock Underground Mines.
[2] Rock bolts to support & stabilize the unstable rock strata in mining & tunnel excavations
[3] Windsor, C.R. 1992. Cable bolting for underground and surface excavations. In Rock support in mining and underground construction, proc. int. symp. on rock support, Sudbury, (eds P.K. Kaiser and D.R. McCreath), 349-376. Rotterdam: Balkema.
[4] Warburton P. M., 1987; Implications of keystone action for rock bolt support and block theory. Int. J. Rock Mech. Min. Sci. & Geomech. Abstr. Vol. 24, PP283-290.
[5] Sinha, S. and G. Walton (2019). "Understanding continuum and discontinuum models of rock-support interaction for excavations undergoing stress-induced spalling." International Journal of Rock Mechanics and Mining Sciences 123.
[6] Dalgic, S. (2000). "The influence of weak rocks on excavation and support of the Beykoz Tunnel, Turkey." Engineering Geology 58(2): 137-148.
[7] Nguyen, Q. P., et al. (2018). "A new design concept of fully grouted rock bolts in underground construction." 2nd International Conference on Sustainable Development in Civil, Urban and Transportation Engineering (Cute 2018) 143.
[8] Yokota, Y., et al. (2019). "Experimental and Numerical Study on the Interface Behaviour Between the Rock Bolt and Bond Material." Rock Mechanics and Rock Engineering 52(3): 869-879.
[9] Esterhuizen, G. S., et al. (2018). "Analysis of monitored ground support and rock mass response in a longwall tailgate entry." International Journal of Mining Science and Technology 28(1): 43-51.
[10] Xanthakos, P. P. (1991) Ground Anchorages and Anchored Structures. John Wiley & Sons Inc., New York, 686 pp.
[11] Kato, J., et al. (2014). "Layout design of rockbolts for natural ground reinforcement." International Journal for Numerical and Analytical Methods in Geomechanics 38(3): 236-255.
