型谱丨奔驰2021发动机、变速箱、车桥资源
Mercedes-Benz Powertrain
在介绍产品前,首先对发动机系统的命名方法做一下说明:
Medium-duty engine systems.
产品一:OM924
产品二:OM926
Heavy-duty engine systems.
产品3:OM457
产品4:OM460
Mercedes-Benz transmissions.
变速箱部分 命名方式:
· 9- to 16-speed transmissions
· Max. input torque from 1400 to 2600 Nm
· Wide gear ratio from 14.57 to 17.11
· Max. permissible gross combination weight (GCW) from 40 to 55 t
· Mechanical shifting systems enable very smooth gear changing and high driving
· Highly variable modular systems for customer-specificsystem solutions· Integrated hydrodynamic retarder
· Quiet running characteristics and long service life through optimized gear set geometry and high-precision processing technologies
· Compact design and weight-optimized metal housing forideal installation dimensions and an ideal power/weight ratio
· Long service intervals and low operating costs due to a fuel-efficient design optimized for customer-specific operating conditions
· More comfortable vibration characteristic
Mercedes-Benz axles.
车桥部分,命名方式:
Wheel-end sizes from 17.5 to 22.5 inches
· Hypoid and planetary driven
· Ring gear diameter from 233 to 485 mm
· Axle loads from 6.2 to 16 t (per axle)
· Gross vehicle weight rating (GVWR) from 6.5 to 250 t
· High fuel efficiency · Easy maintenance and long oil change intervals
· Long lifetime and quiete operations due to our optimized gear set design
· Additional payload due to weight optimized design
· Maintanance-free wheel-hubs
· New Final Drive axle with optimized oil managementreduces fuel consumption
前桥部分
驱动桥部分
