利用Amber进行动力学模拟和结合自由能计算
2022年7月18日 14:21浏览:5120 收藏:2
结构处理
https://www.cgl.ucsf.edu/chimera/download.html
获取晶体结构结构复合物
处理蛋白质
处理配体
上传输入文件到北鲲云计算平台
动力学模拟
antechamber -i ligand.mol2 -fi mol2 -o ligand.ante.mol2 -fo mol2
parmchk2 -i ligand.ante.mol2 -f mol2 -o ligand.frcmod
tleap
source leaprc.protein.ff14SB
source leaprc.gaff
source leaprc.water.tip3p
LIG = loadmol2 ligand.ante.mol2
check LIG
loadamberparams ligand.frcmod
saveoff LIG ligand.lib
saveamberparm LIG ligand.prmtop ligand.inpcrd
REC = loadpdb rec.pdb
check REC
saveamberparm REC receptor.prmtopreceptor.inpcrd
COM = combine {REC, LIG}
saveamberparm COM com.prmtop com.inpcrd
charge COM
solvatebox COM TIP3PBOX 12.0
saveamberparm COM com_solvated.prmtopcom_solvated.inpcrd
Building topology.
Building atom parameters.
Building bond parameters.
Building angle parameters.
Building proper torsion parameters.
Building improper torsion parameters.
total943 improper torsions applied
Building H-Bond parameters.
Incorporating Non-Bonded adjustments.
Not Marking per-residue atom chain types.
(Residues lacking connect0/connect1 -
these don't have chain types marked:
res total affected
<1> 1
CARG 1
NGLY 1
WAT 13849
(norestraints)
Exiting LEaP: Errors = 0; Warnings = 19;Notes = 4.
quit
能量最小化
pmemd.cuda -O -i min.in -o min.out -p com_solvated.prmtop -c com_solvated.inpcrd -r min.rst -ref com_solvated.inpcrd
minimise com
&cntrl
imin=1,maxcyc=2000,ncyc=1000,
cut=8.0,ntb=1,
ntc=2,ntf=2,
ntpr=100,
ntr=1, restraintmask=':1-288',
restraint_wt=2.0
升温模拟
pmemd.cuda -O -i heat.in -o heat.out -p com_solvated.prmtop -c min.rst -r heat.rst -x heat.mdcrd -ref min.rst
heat ras-raf
&cntrl
imin=0,irest=0,ntx=1,
nstlim=25000,dt=0.002,
ntc=2,ntf=2,
cut=8.0, ntb=1,
ntpr=500, ntwx=500,
ntt=3, gamma_ln=2.0,
tempi=0.0, temp0=300.0, ig=-1,
ntr=1, restraintmask=':1-242',
restraint_wt=2.0,
nmropt=1
&wt TYPE='TEMP0', istep1=0, istep2=25000,
value1=0.1, value2=300.0, /
&wt TYPE='END' /
密度平衡
pmemd.cuda -O -i density.in -o density.out -p com_solvated.prmtop -c heat.rst -r density.rst -x density.mdcrd -ref heat.rst
heat ras-raf
&cntrl
imin=0,irest=1,ntx=5,
ntc=2,ntf=2,
cut=8.0, ntb=2, ntp=1, taup=1.0,
ntpr=500, ntwx=500,
temp0=300.0, ig=-1,
restraint_wt=2.0,
体系平衡
pmemd.cuda -O -i equil.in -o equil.out -p com_solvated.prmtop -c density.rst -r equil.rst -x equil.mdcrd
heat ras-raf
&cntrl
nstlim=250000,dt=0.002,
ntc=2,ntf=2,
cut=8.0, ntb=2, ntp=1, taup=2.0,
ntpr=1000, ntwx=1000,
temp0=300.0, ig=-1,
process_mdout.pl heat.out density.out equil.out
xmgrace summary.DENSITY
xmgrace summary.TEMP
xmgrace summary.ETOT
成品模拟
pmemd.cuda -O -i prod.in -o prod.out -p com_solvated.prmtop -c equil.rst -r prod1.rst -x prod1.mdcrd
heat ras-raf
&cntrl
nstlim=500000,dt=0.002,
ntc=2,ntf=2,
ntpr=5000, ntwx=5000,
temp0=300.0, ig=-1,
结合自由能计算
python $AMBERHOME/bin/MMPBSA.py -O -i mmpbsa.in -o result.dat -sp com_solvated.prmtop -cp com.prmtop -rp receptor.prmtop -lp ligand.prmtop -y prod*.mdcrd
Input file for running PB and GB
&general
startframe= 5, verbose= 1,
# entropy= 1,
&gb
igb= 2, saltcon= 0.100
&pb
istrng= 0.100,
北鲲云计算平台作业提交
sbatch -N 1 -p g-v100-1 -c 12 amber.sh
#!/bin/bash
module add Anaconda3/2020.02
source /public/software/.local/easybuild/software/amber/aber20/amber.sh
ulimit -s unlimited
ulimit -l unlimited
pdb4amber -i protein.pdb -o rec.pdb --reduce --dry -y --nohyd
tleap -s -f tleap.in
pmemd.cuda -O -i prod.in -o prod1.out -p com_solvated.prmtop -c equil.rst -r prod1.rst -x prod1.mdcrd
https://pan.baidu.com/s/1n3HuK9dp9o_uTdBjLuPpdQ 提取码: 49x8
以上就是本次教程的所有内容。如果有想学习的软件教程,欢迎在后台留言。
随着科技的进步,科研研究已无需自己配备高性能的计算机,只需要可以登录北鲲云超算平台在线操作即可,为科研的发展提供极大的助力。 以下是 北鲲云超算平台比较吸引我的几点优势,以供大家参考。
高性能计算资源,极大的节省计算成本 -
支持海量的计算工具,且开箱即用 -
计算任务进度实时追踪提示的贴心服务 -
详细耐心的技术咨询
