ABAQUS 输出节点坐标和积分点坐标
浏览:3500 评论:4 收藏:5
In CAE, you can request coordinate outputs by going to the Field Output Request->Edit->Volume/Thickness/Coordinates->COORD, Current nodal coordinates. This way, you will be able to obtain nodal coordinates in ODB, but not the coordinates at the integration points.
In order to get the coordinates at the integration points, you'll have to open the input file (***.inp), and add the keyword COORD under Element Output . This cannot be done in CAE as far as I know.
总结inp中添加关键字
输出单元的积分点坐标:*EL FILE
COORD输出节点坐标:*NODE FILE
COORD原贴出处:https://www.researchgate.net/post/How-to-find-integration-point-coordinates-in-Abaqus-CAE
这是帖子讨论的,但是我的尝试是两个COORD生成的结果文件是一样的,都是节点坐标
