SURFACE ASSEMBLY__M11 CAN ONLY HAVE COUPLED POR...
2023年1月19日 10:39SURFACE ASSEMBLY__M11 CAN ONLY HAVE COUPLED PORE PRESSURE-DISPLACEMENT UNDERLYING ELEMENTS
(1)问题描述
The job input file "Job-1.inp" has been submitted for analysis.
Error in job Job-1: SURFACE ASSEMBLY__M11 CAN ONLY HAVE COUPLED PORE PRESSURE-DISPLACEMENT UNDERLYING ELEMENTS
Error in job Job-1: SURFACE DEFINITION ASSEMBLY__M11 NOT FOUND.
Error in job Job-1: 776 elements are are missing the permeability definition. The elements have been identified in element set ErrElemMissingPermeability.
Error in job Job-1: THE SURFACE ASSEMBLY__M11 HAS NOT BEEN LOCATED
Job Job-1: Analysis Input File Processor aborted due to errors.
Error in job Job-1: Analysis Input File Processor exited with an error.
Job Job-1 aborted due to errors.
(2)问题分析
出现“SURFACE ASSEMBLY__M11 CAN ONLY HAVE COUPLED PORE PRESSURE-DISPLACEMENT UNDERLYING ELEMENTS”问题,多半是出现多个parts;
(3)解决方法
实际物理模型是单个圆筒模型(一个components),由于需要划分六面体网格,所以对模型进行了分割,以满足网格映射得需求。
1) 导入模型文件后,hypermesh出现多个componts,需要把多个components合并为一个(多个经过切分得solids移动到一个components);用collectors功能即可; 作者:仿真资料吧 https://www.bilibili.com/read/cv21279330 出处:bilibili
2) 完成1)中操作后,仅剩下一个component,将component移动到Model中
3) 需要把空的cylinder删除
右键删除即可,下图所示
勾选“Delete part contents”
