刚体的对称约束
We strongly advise you not to apply nodal constraints, for instance, by *BOUNDARY_SPC_OPTION, to nodes of a rigid body as doing so may compromise the intended constraints in the case of an explicit simulation. Such SPCs will be skipped in an implicit simulation and a warning issued.
我们强烈建议您不要将节点约束(例如,通过 *BOUNDARY_SPC_OPTION)应用于刚体的节点,因为在显式模拟的情况下,这样做可能会损害预期的约束。在隐式模拟中将跳过此类 SPC 并发出警告。
所以要使用*MAT-RIGID材料所带的约束(刚体也就6个自由度)
通过将CMO设置为1,CON1控制xyz的位移,CON2控制xyz方向的旋转。
刚体的对称约束的图1
