LSDYNA常见错误与解决办法
浏览:3569 评论:1
*** Error 20216 (STR+216)
part # 6 is out-of-range
>>>>> Process 0 <<<<<
>>>>> Signal 11 : Segmentation Violation <<<<<
计算模态时出现的错误问题
= BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
= PID 54585 RUNNING AT i5611
= EXIT CODE: 9
= CLEANING UP REMAINING PROCESSES
= YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
错误位置无法找到。是因为模型中定义的接触非线性?不至于,因为材料非线性?有可能,怎么办?
正确的输出:
Solving eigenproblem with MPP Lanczos - Global order = 5794551
3 t 1.0000E-05 dt 1.00E-05 write d3eigv file 03/18/25 16:40:10
esolvr_mpp : mxblksize 8
eigenextraction completed
number of eigenvalues found : 10
number of eigenvalues discarded: 0
xdseex warning return : 0
xdseex error return : 0
time for eigenextraction : 9.2645E+01
3 t 1.0000E-05 dt 1.00E-05 write eigout file 03/18/25 16:42:53
N o r m a l t e r m i n a t i o n 03/18/25 16:42:53
material type 100
that is invalid for belytschko-schwer beam elements
错误:传统梁单元不能用MAT100
错误:关闭AUTOSPC
*CONTROL_IMPLICIT_SOLVER
$ lsolvr lprint negeig order drill dparm autospc aspctl
14 1 0 0 0 0 2 0
*** Error 60047 (IMP+47)
* - FATAL ERROR - *
* AUTOSPC detected very large entries in the *
* assembled matrix. These are probably caused *
* by overflow during elemental matrix computations. *
* This could be caused by an energy explosion. *
* Recommend switching to the REAL*8 version of LS-DYNA.*
*** Error 10267 (KEY+267)
in converting external to internal
单元没有节点,看看是不是在别的INCLUDE文件中。
递进式模型调试的必要性!
隐式分析中遇到的问题,如何应对?
*** Warning 60123 (IMP+123)
* - WARNING - *
* 207 negative eigenvalues detected during *
* factorization of linear equation system. *
* Errors during stiffness matrix inversion are *
* often caused by one of the following problems: *
* 1) Invalid material properties (negative *
* Young's Modulus, zero yield stress...) *
* 2) Inverted element from severe distortion. *
* 3) Rigid Body Modes. Generally, three nodes *
* must be constrained in static analysis. *
* See the User's Manual for more information. *
*** Warning 60058 (IMP+58)
At least one small pivot detected during factorization.
First node: 2266376 dof: Ma
*** Error 11003 (KEY+1003)
Contact definition 1000200 ID 1000200 is a TIED_SHELL_EDGE_TO_SURFACE_(OPTION) type
and cannot use segment set for the slave side
记得之前也遇到过:
rcmd: socket: Permission denied,不清楚为什么。
如果不去尝试建立正确的刚度模型,那么动力学模型的精度还能保证吗?关键的接触关系还可靠吗?
复合材料的建模、材料模型、失效模拟
