spaceclaim所有命令
浏览:2605
Command:
Activate Component
Used by:
Locate in Structure Tree 忏 Measure
Move
Move Along Trajectory(Alt+click) Move Direction(Alt+click)
Move radially about axis Move to New Component New Component
Open Component
Orient
Orient to Object
Pull
Pull Direction(Alt+click) Revolve(Alt+click)
Rounds
Ruler
Scale Body
Select
Select
Select Component
Show All Faces
Split Body
Stitch
Style Override/Opaque
Style Override/Transparent Sweep(Alt+click)
Tangent extension
Up To
Up To
Ribbon Commands
出
A
滤
Q
一
A 电
“X
2022 R1
2D Move
3D Markup 3D Mode
45-Degree Bevel Notch About KeyShot
Add
Add Control Curve Add/Edit
Align Align
Allow attaching placements to geometry Anchor
Annotate GD&T As File
As Outlook Attachment As Web Viewer Link
Associate
Auto Fix Auto Skin
Auto Update Validations Autoconstrain
Axis
Back
Bad Faces
Balloon/ltem Number
Balloon/ltem Number and Quantity Balloon/Part Number
Barcode Label
Bead Beads
Beams D--」
Broken
Broken-Out Section
Camera/Orthographic Camera/Perspective
Cavity
Center
Center Line Check Body
Coincident Constraint
Color Cha ed Faces
Color/Ran mize Colors
Combine Comment
Complete
Composite Frame
Concentric Constraint Connect
Construction Line Contact Detection Continue
Control Curves Control Points Convert
Convert
Convert to Selection Copy
Copy
Copy Measured Value Corner Relief
Cosmetic
Cosmetic Replay Counterbore
Countersink
Create
Create
Create
Create Beam
Create Block and Block Inserts Create Book...
Create Corner
XCreate Corner
Create lmport Group Test..
Create Model Statistics Report
Create Transformed Component Create UI Report
Create Video
Create video..
Create Workpiece Cross Section
Curvature
Curvature
Curve Gaps Curve Table Curves
Cut
Cylinder
Datum Symbol
&Datum Target Debug
W
7
瞻
Q
口
口
Debug Dump
Decode GDT
Decrease Width Factor Default
Delete
Delete Constraint
Depth-to-Shoulder
Depth-to-Tip
Design
Design and Drawing Sheet Detail
Deviation
Sketch/Me
Click a line
Drawing Sheet
Sketch/Me
Click a line
Echo
Ln Edge Relief
Edges
Edges
Edges/Facets Edges/nternal
Edges/Open
Edges/Silhouette
Edges/Soft
Edges/Solid
Edges/Surface
Edges/Tangent
Editable Text
Elipse
口 Empty Drawing Sheet 6 Enable 3D Sketch
Enclosure
Enclosure
Encode GD&T
√ End Sketch Editing
H Equal Distance Constraint
Equal Length Constraint Equal Radius Constraint Equation
Exit SpaceClaim Expand
Expand Selection in Blue
Expand Selection in Red
Explodable Explode
Extend
Extend Facets Selection
Extra Edges
Extra Edges
Extract
Extract Curves
Face Curve
Faces
Faces
Fade Scene
Fade Shading
Fan
File
File Report.
Fill
Fill
Fill Pattern
Filled
Find Option …
Fit Curves
Fit Spline
Fix Layer
Facets/Select/
Get similar tria
Fixed Constraint Flange
Flange
Flawed Topology
Fluent 2022 R1/Custom New Workflow Fluent 2022 R1/Export PMDB
Sketch/E
Fluent 2022 R1/Mesh to Solver
Fluent 2022R1/Watertight Geometry Workflow Fold Walls
Force Save All
Force Share
Format/Apply to AlI Sheets
Format/More Formats...
Format/RemoveCurrent Format Formed Bends
Forms
Free Beam Display/More Colors … Free Beam Display/No Point
Free Beam Display/One Point
Free Beam Display/One point beam Color Free Beam Display/Single beam Color
Free Beam Display/Two Point
Free Beam Display/Two point beam Color Free Edge Display/Double
Free Edge Display/Free Double Edge Color
Free Edge Display/Free Double Edge Thickness
Free Edge Display/Free Single Edge Color
Free Edge Display/Free Single Edge Thickness
Free Edge Display/Single Free Edge Display/Thick
Sketch/E
Fill the sel
Free Edge
Free Edge
Display/Thin
Display/Thin
二 -
Highlight/Junctions Highlight/Miters
Highlight/Notches
Highlight/PanelBends
Highlight/Reliefs Highlight/Sheets
Highlight/Tabs
Hinge
国 Hole Table Holes
Home
Horizontal
Horizontal Constraint
ldentify Objects Imprint
ldentify Objects
Imprint
W Increase Width Factor
Inexact Edges
Insert Drawing From File
Insert/Add Symbol Library …
Insert/Remove Symbol Library
Interference Internal
Intersect
Intersections Invite
lsometric Italic
Joggles
Join
s
a
Junction
Keyboard Shortcuts
Z Laser Symmetric 瑞 Last Markup
Layers
① Least Material Condition
Left
Left
D9 Left-to-Right
Line
Line
Line
Line Style/Line Style by Layer Linear Pattern
Linear Pattern
Lineweight/Lineweight by Layer Log File
Maintain an upward orientation for Manage Web Viewer Files
Map/Sweep
Marker
Mass Properties
Match
⑧ Maximum Material Condition 忡 Measure
M Mechanical
Mechanical 2022 R1 Merge
Merge
Merge Faces
Mesh
Midpoint Constraint
Midsurface
Minimize the Ribbon
Mirror
Missing Faces
Miter
Model space
Move
Move
Move Body
图 New Slide
New Window
1 VISCL LUIvC On Center
On Cursor
四 On/Off Open
Open S Open
Open
影 Open Wizard
回 Opening
Options
Ordinate Dimensions
Orient
Orient
田
Volumes Watch.
Weld
Welding Symbol Wrap
Wrap Assembly
Write ACMO Mesh
Write Full Report
Write Mesh Diagnostics Write Meshing State Log Write Region EV Mesh
Write Summary Report
Write Validation Data to Journal File XY Bevel Notch
Zoom
Zoom Box In Zoom Extents Zoom In
Zoom Out
Zoom to Fit
a
She Lase
