abaqus出现system error code 65535错误
做显式动态分析时 分析步为Dynamic explicit时怎么老出现
这样的错误:
Error in job Job-1: The executable C:\Program aborted with system error code 65535. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command " ABAQUS job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
