求教
浏览:152712 回答:1
ansys在分析结合面是用得弹簧阻尼单元,其本构关系是什么啊?
正在做这方面的课题,很是郁闷~~
谢谢大侠帮助!
沙漠绿洲_5119
COMBI165 Input Data
The real constants Kd to TDL are optional and do not need to be defined.
For example, if Kd, the dynamic magnification factor, is nonzero, the forces computed from the spring elements are assumed to be the static values and are scaled by an amplification factor to obtain the dynamic value:
在帮助文档中就可以找到
2008年8月16日
