CFX中如何调用用户函数?
浏览:76546 回答:2
在做例子9时,打开Tools > Command Editor,输入! system ("cfx5mkext PipeValve_inlet.F") < 1 or die;然后按process,结果出现错误,The compiler command "ifort" coule not be found.Please ensure that the compiler is on your PATH and try again. 请问高手如何解决!!!
