错误提示
浏览:179281 回答:2
*** ERROR *** CP = 97.875 TIME= 08:48:20
*** MESSAGE CONTINUATION ---- DIAGNOSTIC INFORMATION ***
Rigid body motion can also occur when net section yielding has
occurred resulting in large displacements for small increments of load
or when buckling has occurred. You can plot the time history curve
for node 9226 in the UZ direction to check for stiffness (slope of the
curve) approaching zero.
syjzwk
仅仅因为弯曲或是好、小的荷载增量就导致刚体位移吗,如何消除呢
2009年11月9日
syjzwk
边界条件都已施加,为何总是出现这种错误提示,导致求解中断
2009年11月9日
