abaqus问题--Job spinning aborted due to errors.
浏览:162917
做到最后,出现这个问题:
Detected lock file spinning.lck. Please confirm that no other applications are attempting to write to the output database associated with this job before removing the lock file and resubmitting.
请问如何解决?谢谢!
