Fe-safe结合Abaqus算疲劳
浏览:114688
最近需要计算一个两个物体接触问题的疲劳,由于abaqus疲劳功能较弱,故结合Fe-safe进行计算,但是在Fe-safe导入odb文件后出现了如下问题,由于偶是新手所以拜托各位相助,大家一起交流~
错误:
There were 2 instances of element 1 in the first
step found in model 'yuan1.odb'.
This is probably due to multiple part instances in
your model. There are 2 part instances.
fe-safe cannot deal with non unique element numbers
Please flatten your model using the ABAQUS/CAE command
mdb.models['Model-1'].setValues(noPartsInputFile=ON)
where Model-1 is your model name
and then re-create your results .odb as a flattened model.
Using the model you have just loaded will have
unpredictable behaviour !
