memory access exception
浏览:72782 回答:1
SIGSEGV: memory access exception
Command: SaveState
In: [Machine::main, SimulationStateSaver::save]
Recoverability: Non-recoverable
ServerStack: [SymInit: Symbol-SearchPath: '.', symOptions: 530, UserName: 'lenovo'
, OS-Version: 6.1.7601 (Service Pack 1) 0x300-0x1
, 000000000043A384 (StarNeo): (filename not available): SaveProperties::set
, 0000000002A71AA6 (StarCommon): (filename not available): BoundaryInterface::getProperties
, 0000000002B458C1 (StarCommon): (filename not available): DirectBoundaryInterface::getProperties
, 0000000000385DA7 (StarNeo): (filename not available): ClientServerObject::save
, 00000000003F36A1 (StarNeo): (filename not available): NamedObject::save
, 0000000002C2482E (StarCommon): (filename not available): Interface::save
, 0000000002E5144F (StarCommon): (filename not available): SimulationStateSaver::performSave
, 0000000002E4EDB5 (StarCommon): (filename not available): SimulationStateSaver::save
, 0000000002E453FB (StarCommon): (filename not available): SimulationStateRestorer::save
, 0000000002D5C04F (StarCommon): (filename not available): SimulationStateRestorer::getRootNode
, 00000000003B30A6 (StarNeo): (filename not available): Controller::executeCommand
, 00000000003B1995 (StarNeo): (filename not available): Controller::processCommands
, 000000018000FC91 (StarMachine): (filename not available): CommandController::processCommands
, 00000001800ACAF4 (StarMachine): (filename not available): Machine::startServerHost
, 00000001800A1DAE (StarMachine): (filename not available): Machine::main
, ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 00000001400012CD)
, 00000001400012CD (star-ccm+): (filename not available): (function-name not available)
, ERROR: SymGetSymFromAddr64, GetLastError: 487 (Address: 0000000140004D8E)
, 0000000140004D8E (star-ccm+): (filename not available): (function-name not available)
, 000000007701652D (kernel32): (filename not available): BaseThreadInitThunk
, 000000007784C521 (ntdll): (filename not available): RtlUserThreadStart
Signal: SIGSEGV: memory access exception
error: Server Error
这是不是代表我的STAR安装的有问题还是怎么样,仅仅是内存不够吗
Command: SaveState
error: Server Error
第二,软件问题,安装出错;
第三,网格文件问题!
