workbench中怎么插入command?
浏览:73600 回答:1
不知道是什么问题,出现这个警告太多次,总共超过了10000次,ansys计算自动停止。Number of error messages exceeds user specified maximum of 10000
Use the /NERR command to increase the number of messages
ANSYS run terminated by this error. 现在想怎么通过workbench中的transient structure 中插入command命令,增加警告次数,系统默认是10000次。下面是警告。
*** WARNING *** CP = 81.245 TIME= 23:35:24
A reference force value times the tolerance is used by the
Newton-Raphson method for checking convergence. The calculated
reference FORCE CONVERGENCE VALUE = 1.146880107E-04 is less than a
threshold. This threshold defaults to 1.0-2 or is specified as MINREF
on the CNVTOL command. Check results carefully.
MOMENT CONVERGENCE VALUE = 0.1580E-06 CRITERION= 0.5206E-04 <<< CONVERGED
zhzhfe0405
我也遇到这个问题 你解决了吗?
2013年6月4日
