Logo 折叠
全网首发仿真工程师项目实训
下载app
返回旧版
首页 成长助手 小邻学院 社区 发现
职业认证 企业服务 行业会议
登录解锁更多功能
还没有账号?立即注册
技术邻
技术引领职场价值
电话
0571-86682823
商务合作
service@jishulink.com
遇到以下问题 求指点
浏览: 45694
Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint including mpcs, rigid bodies, etc.
For contact pair (assembly__pickedsurf469-assembly__pickedsurf468), adjusted nodes with very small adjustments were not printed. Specify *preprint,contact=yes for complete printout.
The ratio of the maximum incremental adjustment to the average characteristic length is 1.64259e-02 at node 46 instance beam-1 on the surface pair (assembly__pickedsurf475,assembly__pickedsurf474).
Not all the nodes that have been adjusted were printed. Specify *preprint,contact=yes for complete printout.
Boundary conditions are specified on inactive dof of 64 nodes. The nodes have been identified in node set WarnNodeBCInactiveDof.
The strain increment has exceeded fifty times the strain to cause first yield at 1728 points
Excessive distortion at a total of 320 integration points in solid (continuum) elements
ABAQUS CAE 结构CAE
全部回答 (0)
相似问题
查看全部
  • 关于abaqus计算不收敛的求助!! 暂无回答
    本人在模拟一个钢筋混凝土框架结构在竖向荷载及水平周期反复荷载作用时一直出现如下警告,然后计算一直不收敛。还望各位大神指点。模型在下方。 VF.zip Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation)
  • 建立钢筋混凝土框架的时候,梁柱利用你tie约束连接的时候出现了问题? 7个回答
    软件:Abaqus 问题: Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other constraint
  • 请问一下,下面这些警告信息怎么处理? 2个回答
    请问一下,下面这些警告信息怎么处理?? Whenever a translation (rotation) dof at a node is constrained by a kinematic coupling definition the translation (rotation) dofs for that node cannot be included in any other cons
推荐阅读
ABAQUS中级教程合集--搞定滞回曲线
1点 1点
¥299
Apex For Aerospace Applications Introduction
MSC Apex
免费
公路钢筋混凝土及预应力混凝土桥涵设计规范解决方案
敦樸DUNPU 敦樸DUNPU
免费
慧加新规范解决方案详解之大跨连续弯梁桥精细化分析(7DOF)
敦樸DUNPU 敦樸DUNPU
免费
混合弯头的流体流动与传热
混合弯头的流体流动与传热
CFD流 CFD流
免费
Abaqus子程序安装教程 Abaqus6.14.2+VS2013+IVF2013(附带安装包)
二十 二十
免费
北京华盛扬科技 北京华盛扬科技
¥9.9
Msc Apex For Aerospace Applications Idealization a
MSC Apex
免费
超大规模芯片电源完整性签核平台RedHawk-SC应用分享
Ansys中国 Ansys中国
免费
ALTAIR ALTAIR
免费
结构仿真职业规划与学习路线
结构仿真职业规划与学习路线
技术邻直播 技术邻直播
免费
人工智能工程应用实例: 发动机排放数据学习及预测
IDAJ中国 IDAJ中国
¥99
Altair二次开发答疑&典型案例解读
Altair二次开发答疑&典型案例解读
ALTAIR ALTAIR
¥10
MATLAB/ADAMS求解动力学
MATLAB/ADAMS求解动力学
伟_sss 伟_sss
¥25
基于OptiSturct的线性静力学分析和尺寸优化
Leon_sun Leon_sun
¥10
Abaqus在高科技与电子行业的应用(达索直播课程)
水木人CAE-林丽 水木人CAE-林丽
¥10
AQWA软件企业培训(3)  通过ANSYS-APDL建立半潜平台混合模型及混合模型的拖曳力线性化
Nutshell Nutshell
¥30
TurboTides TurboTides
免费
UG编程零基础入门到精通以及优化刀路教程
UG编程 UG编程
免费
abaqus座椅滚轮拉脱力强度分析
abaqus座椅滚轮拉脱力强度分析
任总 任总
¥90
