ABAQUS温度积分点如何设置? 50
浏览:1008 回答:1
各位大佬好,我做了一个各向异性复合材料5层壳单元 ,每层3个积分点,两个完全相同的模型,第一个模型给了一端0度一端100度的热传递,第二个模型通过预定义场将模型一得到的温度场施加给这个模型,为什么算出来只有第一层施加成功了,有图中的警告该如何处理
IN.
图片看不太清楚,警告是The parameter temperature in *shell section is not present but at least one *temperature keyword has file parameter. It will be assumed that the number of temperature points is 11 that is same as the maximum number of integration points through the shell thickness present in the previous heat transfer analysis. There are too few data cards for the initial conditions option. All remaining values are assumed to be zero. The number of temperature points 11 for beam or shell section found on the output database is smaller than in the current model. This number must match between models.
2025年8月31日
