[求助]各位大神帮忙看看
浏览:170198
mesh>creat>tetramesh process >creat new 出错,如下:org.mozilla.javascript.JavaScriptException: java.lang.NullPointerException
while executing
"# Compiled -- no source code available
error "called a copy of a compiled script""
(procedure "::hw::pmgr::PmgrCreateNewProcessInstance" line 1)
invoked from within
"::hw::pmgr::PmgrCreateNewProcessInstance $str_fullInstancePath"
(procedure "::altair_pmgr::launch::OnNewInstance" line 22)
invoked from within
"::altair_pmgr::launch::OnNewInstance "tetmesh.pmt" .pmgrLaunchInstanceGUI"
("eval" body line 1)
invoked from within
(procedure "::hwt::ReleaseCanvasButton" line 1)
invoked from within
"::hwt::ReleaseCanvasButton 0 .pmgrLaunchInstanceGUI.actionFrame.acceptButtonActiveFrame.acceptButton"
(command bound to event)
