带有裂缝问题可以进行热分析吗?
浏览:25424 回答:1
求助,如题!单纯的热分析、带裂缝实体的力学分析(xfem)已经实现!
希望对预设carck(xfem)的实体进行热分析,缝面的thermal-contact depend on clearance~
请问在做类似算例时要注意什么?或者说热分析就不能分析带有(xfem)crack的实体?
错误提示:
Job paltewithcrack-heat: Analysis Input File Processor completed successfully.
ERROR in job messaging system: Error in connection to analysis
Error in job paltewithcrack-heat: The executable standard.exe aborted with system error code 1073741819. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job paltewithcrack-heat aborted due to errors.
“Error in job paltewithcrack-heat: The executable standard.exe aborted with system error code 1073741819.”网上说是内存的问题。但是我的算例很简单,不会有内存不够的问题出现。
liuyang18539
1、如果你没装ansys的话,那就是你的工作目录:C:ABAQUS///Temp里有汉字,修改一下工作目录就行了。
2、上述没问题的话,6.XX,版本就把abaqus中文件mkl_avx2.dll改名为mkl_avx2.XX.0.0.1.dll解决。
2014年9月15日
