abaqus子程序部分无法pass
浏览:64222
Abaqus Product Install Verification...
Sun Nov 24 17:30:40 2013
Running system requirement checks.
Requirement: Windows Server 2003, Windows Server 2008, Windows Server
2008 R2, Windows HPC Server 2008, Windows XP, Windows Vista,
or Windows 7
Product: All Abaqus Products
Status: Pass - Found Windows 7 Enterprise Service Pack 1 (Build
7601) (x64).
Requirement: Microsoft Visual C++ 9.0 (2008), or 10.0 (2010)
Product: Abaqus make utility with C++
Status: Pass - Found Microsoft Visual C++ 9.0.21022.8.
Requirement: Intel Fortran Compiler 10.1, or 11.1
Product: Abaqus make utility with Fortran and Abaqus with user
subroutines
Status: Pass - Found Intel Fortran Compiler 11.1 Build 20090624
Package ID w_cprof_p_11.1.038.
Requirement: MS-MPI 2.0, 3.0 or greater
Product: Abaqus analyses using MPI-based parallelization and
Abaqus/CFD
Status: Fail - Unable to locate a supported MPI implementation on
this system. For more information on the MPI-based parallel
functionality, see the section 'Parallel processing modes in
Abaqus' in the Abaqus Analysis User's Manual.
Requirement: Internet Explorer 6.0 or 7.0 or 8.0, Firefox 2.0 or 3.0 or
3.5 or greater
Product: Abaqus Documentation
Status: Pass - Found Internet Explorer 11.0.9600.16428
Found C:\Temp\verify. All verification files will reside in this directory.
Old job files exist. They will be moved to verifyOLD.
Abaqus/Standard
...PASS
Continuing...
Abaqus/Standard with user subroutines
...PASS
Continuing...
Abaqus/Explicit (single precision)
...PASS
Continuing...
Abaqus/Explicit (double precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (single precision)
...PASS
Continuing...
Abaqus/Explicit with user subroutines (double precision)
...PASS
Continuing...
Abaqus/Viewer
...PASS
Continuing...
Abaqus/CAE
...PASS
Continuing...
Geometry Translator for CATIA V4
...ERROR
Geometry translation failed. Please see CATIAv4.rpy
for details.
Continuing...
Geometry Translator for CATIA V5
...ERROR
Geometry translation failed. Please see CATIAv5.rpy
for details.
Continuing...
Direct Geometry Import for CATIA V5
...PASS
Continuing...
Geometry Translator for I-DEAS
...ERROR
Geometry translation failed. Please see IDEAS.rpy
for details.
Continuing...
Geometry Translator for Parasolid
...ERROR
Parasolid.rpy for details.
Continuing...
Geometry Translator for Pro/ENGINEER
...ERROR
ProENGINEER.rpy for details.
Continuing...
SolidWorks Associative Interface
...PASS
Continuing...
Abaqus/AMS
...PASS
Continuing...
Abaqus Interface for MSC.ADAMS
...PASS
Continuing...
Abaqus/Standard parametric studies
...PASS
Continuing...
Abaqus/Explicit parametric studies
...PASS
Continuing...
Abaqus/Design
...PASS
Continuing...
Abaqus Interface for Moldflow
...PASS
Continuing...
...PASS
Continuing...
...PASS
Continuing...
Abaqus make utility with object code
...PASS
Continuing...
Abaqus scripting interface
...PASS
Continuing...
Abaqus analyses using parallelization
Running thread-based parallel with 2 cpu(s)
Abaqus/Explicit domain-level parallel
...PASS
Abaqus/Standard direct solver
...PASS
Continuing...
Abaqus/Foundation
...PASS
Continuing...
Abaqus noGUI (CAE/Viewer)
...PASS
Continuing...
Abaqus/CFD
...INFORMATION
System requires were not met. Verification
procedure will be skipped
Continuing...
Clean-up...
Job files exist. Verification directory C:\Temp\verify will not be deleted.
