运行DYNA后message出现错误!求大神指点
浏览:45269
S-DYNA user input
ls-dyna ls971s.53450 R4.2.1 date 06/08/2009
expanding memory to 2209 material, node and element data
expanding memory to 2285 material properties
expanding memory to 591358 element data
expanding memory to 680229 gradient of damage data
expanding memory to 1459326 user control for contact interfaces
expanding memory to 1459328 for boundary cond. vectorization
contracting memory to 1459306 nodal data
expanding memory to 1511242 arbitrary element numbering input
expanding memory to 1814749 spc cards
expanding memory to 2430862 process element material data
expanding memory to 2432863 load curve data
contracting memory to 2431064 regularize time history data
contracting memory to 2430864 rigidwall definitions
expanding memory to 2469653 nodal constraint sets
expanding memory to 2885506 contact interfaces
expanding memory to 2922048 implicit contact 1
expanding memory to 3129794 implicit contact 2
*** Error part # 1 is out-of-range
input phase will continue if possible
*** Error part # 2 is out-of-range
*** Error part # 4 is out-of-range
expanding memory to 4592267 contact segment data 1
contracting memory to 4485791 contact segment data 2
expanding memory to 5061218 contact segment data 3
expanding memory to 7860789 contact definition
expanding memory to 7914216 rigid body
expanding memory to 8341161 contact friction
expanding memory to 8447787 rigid body b.c.
expanding memory to 9407382 joints
contracting memory to 9407382 shell solid interfaces
contracting memory to 9407382 accelerometers
expanding memory to 9407482 rigid bodies for disp. termination
contracting memory to 9407482 transformation to move nodes
expanding memory to 9407483 thermal expansion 0
expanding memory to 9407484 flexible body 2
contracting memory to 9407484 implicit joints
input phase completed with 5 fatal errors
please check messag file
