电磁—热耦合场问题
浏览:98166
在用GUI方式进行电磁—热耦合场求解时出现如下的错误,哪位大神知道原因呀?请大家不吝赐教,谢谢!“ The value of TEMP at node 514 is 5.087171252e+17. It is greater than the current limit of 1000000. This generally indicates rigid body motion as a result of an unconstrained model. Verify that your model is properly constrained."
