Too many attempts made for this increment
浏览:51084
做了一个小案例,结果提示错误:
Abaqus/Standard Analysis exited with an error - Please see the message file for possible error messages if the file exists.
警告:
The dilation angle is small or zero. The value will be set to 0.10000
There are 3 unconnected regions in the model.
模型上面是个荷载板,中间是硬土层,下面是软土层。边界是左右和下面固定,请问如何解决
