cfx中出现问题
浏览:139147
在操作中出现
In Analysis 'Flow Analysis 1': Unit conversions will not be applied to data transferred between the solvers. To enable these conversions, select a pre-defined system of solution units for the ANSYS solver using the /UNITS command in the Input File.
该怎么解决?
ansys中的命令流:/units,si
solution units也用的是si
