新人求教!ABAQUS软件T300平板拉伸到断裂
浏览:40405 回答:1
刚刚接触ABAQUS软件 运行的时候有好多错误,怎么改都改不对,求指导
60 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
Section definitions are missing or incorrect for the elements indicated above. Further processing of the input file is not possible until this input error is fixed.
Analysis Input File Processor exited with an error.
zxmyt21
已经解决了 谢谢
2014年6月10日
