求大神帮忙。。。运行子程序出错
浏览:187676
Problem during linking - Abaqus/Standard User Subroutines. This error may be due to a mismatch in the Abaqus user subroutine arguments. These arguments sometimes change from release to release, so user subroutines used with a previous release of Abaqus may need to be adjusted.
用的是abaqus6.10 iIntel.Visual.Fortran2011.Composer.XE vs2010
