abaqus 梁单元截面壁厚问题
浏览:16051 回答:1
One or more thickness of the box section is greater than 0.1 of the cross section dimension. The torsional rigidity may not be evaluated accurately since the calculation is based on the assumption that the wall thickness is much small in comparison to the cross section dimension
用梁单元该怎么处理?实际截面6X3.6m,壁厚,1.3m和0.8m
yuyu1984
不知道啊!我也是新手!
2015年1月23日
