【求助】abaqus显示分析采用多个cpu就报错
浏览:5534 回答:3
选择单个cpu可以正常计算,但是模型比较大,计算时间过长
但是选择多个cpu计算时就报错
求大神指点!!!
下面是status file里的错误信息:
***ERROR: The requested number of domains cannot be created due to
restrictions in domain decomposition. The following limitations may
be helpful in understanding this behavior:
1. Contact pair requires that the surface nodes be in the same domain.
In the case of kinematic contact, elements associated with
the surface facets must also be in the same domain.
2. An adaptive mesh domain must be contained within a single
parallel domain. Nodes on the boundary between an adaptive
mesh domain and a nonadaptive domain must not be shared
with other parallel domains.
3. All the nodes involved in a kinematic constraint must
be in the same domain and must not be shared with other domains.
4. Nodes associated with beam elements whose center of mass
does not coincide with the location of the beam node or which
use the *BEAM ADDED INERTIA option must be within a single domain.
homeland
其实提示已经说明了:系统不能创建多个计算区域,因为多cpu是每个计算一部分然后合成起来。
可能的原因是它说的几个办法试一试……
2015年9月13日
867797140
同求啊 不知楼主知道原因了么
2015年9月12日
305245989
求大神指点
2015年1月27日
