abaqus 结构实例
浏览:6255 回答:2
小弟新手在用abaqus做一个 钢管混凝土拱和钢骨混凝土柱结构力学性能的模拟(要求求出屈服、极限荷载) ,建的模型能算出结果但出现太多警告提示,如下 For *tie pair (assembly__pickedsurf641-assembly__pickedsurf640), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
For *tie pair (assembly__pickedsurf433-assembly__pickedsurf432), adjusted nodes with very small adjustments were not printed. Specify *preprint,model=yes for complete printout.
Slave node 10 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 74 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 75 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 76 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 77 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 78 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 80 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 81 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 83 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 84 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 85 instance part-2-1 will not be tied to the master surface assembly__pickedsurf640. The distance from the master surface is greater than the position tolerance value.
Slave node 1 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 11 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 12 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 13 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 14 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 15 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 17 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 18 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 20 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 21 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
Slave node 22 instance part-2-1 will not be tied to the master surface assembly__pickedsurf432. The distance from the master surface is greater than the position tolerance value.
44 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
728 elements are distorted. Either the isoparametric angles are out of the suggested limits or the triangular or tetrahedral quality measure is bad. The elements have been identified in element set WarnElemDistorted.
不知怎么解决,望高手能给于解决方案。
叶重
接触问题,重新画网格
2017年11月29日
李懋军
请问楼主解决这个问题了吗?我也遇到,跪求指教
2015年9月7日
