求助大神:这些错误怎么产生 ?要怎么解决呀?
浏览:11049
The cpset or the surface parameter must be specified for history contact output
The nset parameter can only be used for bondstat or bondload output
Output request ctrq is not available for this option
The geometry of 1 elements is too distorted. Check the nodal coordinates or node numbering on elements identified in element set ErrElemDistorted.
Analysis Input File Processor exited with an error.
