关于结果文件,只生成了master文件,无法生成xdb文件
浏览:16097
如题。求教各位大神如何解决这个问题,这个问题困扰我很久了。所有的结果分析文件都是master格式,无法生成xdb格式。怎么设置。下面是f06文件*** USER FATAL MESSAGE 108 (SCA.MDSolver.Obj.InputFile.InputFile::read)The input stream data file C:\Users\timelesa does not exist.
*** USER WARNING MESSAGE 209 (SCA.MDSolver.Io.AccessAccess.AccessAccess::isEchoSortRequested)
No stream input file has been converted to its binary form using StreamToBinary.
The ECHO data returns will all be false.
*** SYSTEM FATAL MESSAGE 501 (SCA.MDSolver.Io.AccessAccess.AccessDatabase::open)
Error 1 occured while attempting to open database ./zuoye.IFPDAT.
^^^ >>> IFP OPERATIONS COMPLETE <<<
^^^ USER FATAL MESSAGE 9002 (IFPS)
^^^ ERROR(S) ENCOUNTERED IN THE MAIN BULK DATA SECTION
^^^ SEE MESSAGES ABOVE. ERROR ENCOUNTERED IN MODULE IFP,
1 MSC.NASTRAN JOB CREATED ON 25-JUN-15 AT 15:05:25 JUNE 25, 2015 MD NASTRAN 4/27/11 PAGE 4
0
0
*** USER INFORMATION MESSAGE 4425 (PRTPRN)
ONE OR MORE FATAL ERRORS HAVE OCCURRED. THERE MAY BE MORE ERROR MESSAGES IN THE PRECEDING OUTPUT
1 MSC.NASTRAN JOB CREATED ON 25-JUN-15 AT 15:05:25 JUNE 25, 2015 MD NASTRAN 4/27/11 PAGE 5
0
* * * * D B D I C T P R I N T * * * * SUBDMAP = PRTSUM , DMAP STATEMENT NO. 40
0 * * * * A N A L Y S I S S U M M A R Y T A B L E * * * *
0 SEID PEID PROJ VERS APRCH SEMG SEMR SEKR SELG SELR MODES DYNRED SOLLIN PVALID SOLNL LOOPID DESIGN CYCLE SENSITIVITY
0SEID = SUPERELEMENT ID.
PEID = PRIMARY SUPERELEMENT ID OF IMAGE SUPERELEMENT.
PROJ = PROJECT ID NUMBER.
VERS = VERSION ID.
APRCH = BLANK FOR STRUCTURAL ANALYSIS. HEAT FOR HEAT TRANSFER ANALYSIS.
SEMG = STIFFNESS AND MASS MATRIX GENERATION STEP.
SEMR = MASS MATRIX REDUCTION STEP (INCLUDES EIGENVALUE SOLUTION FOR MODES).
SEKR = STIFFNESS MATRIX REDUCTION STEP.
SELG = LOAD MATRIX GENERATION STEP.
SELR = LOAD MATRIX REDUCTION STEP.
MODES = T (TRUE) IF NORMAL MODES OR BUCKLING MODES CALCULATED.
DYNRED = T (TRUE) MEANS GENERALIZED DYNAMIC AND/OR COMPONENT MODE REDUCTION PERFORMED.
SOLLIN = T (TRUE) IF LINEAR SOLUTION EXISTS IN DATABASE.
PVALID = P-DISTRIBUTION ID OF P-VALUE FOR P-ELEMENTS
LOOPID = THE LAST LOOPID VALUE USED IN THE NONLINEAR ANALYSIS. USEFUL FOR RESTARTS.
SOLNL = T (TRUE) IF NONLINEAR SOLUTION EXISTS IN DATABASE.
DESIGN CYCLE = THE LAST DESIGN CYCLE (ONLY VALID IN OPTIMIZATION).
SENSITIVITY = SENSITIVITY MATRIX GENERATION FLAG.
No PARAM values were set in the Control File.
0
0
0
VERS = VERSION ID.
