求助:Nastran任务log提示访问拒绝错误
浏览:7154 回答:1
求教各位专家,我正在搭建Nastran的学习环境,遇到一个问题,想得到各位的指导。平台环境如下:
硬件:Intel Xeon E3-1230 4核CPU,8G内存,500G硬盘
系统:Windows 7 64位 SP1
软件:1)msc_licensing_11.9_windows3264 license Server,已经成功导入license文件,服务器状态显示:
Status
Flexible License Manager status on Sun 8/9/2015 14:47
[Detecting lmgrd processes...]
License server status: 27500@sunshine-home
License file(s) on sunshine-home: D:\MSC.Nastran2012\MSC.Licensing.11.9_License\license.dat:
sunshine-home: license server UP (MASTER) v11.9
Vendor daemon status (on sunshine-home):
MSC: UP v11.9
Feature usage info:
Users of ABS: (Total of 16777216 licenses issued; Total of 0 licenses in use)
Users of ACIS: (Total of 16777216 licenses issued; Total of 0 licenses in use)
2)nastran_2012.2_windows3264,安装时正常完成,基本都是默认的安装选项,但是调用其D:\MSC.Software\MSC_Nastran\20122\bin\nastranw.exe来计算一个任务时(任务的dat文件就软件自带的example D:\MSC.Software\MSC_Nastran\20122\msc20122\nast\tpl\*),发现该任务log信息报错,具体信息如下:
MSC.Nastran V2012.2 (Intel Windows 7 Ultimate 6.1 7601) Control File:
Nastran BUFFSIZE=8193 $(d:/msc.software/msc_nastran/20122/conf/nast20122.rcf[2])
Nastran REAL=2127560704 $(program default)
JID='d:/msc.software/msc_nastran/20122/msc20122/nast/tpl/1dstrain/tst1d1.dat'
OUT='./tst1d1'
MEM=33554432 $ WORDS
MACH='Intel'
OPER='Windows 7 Ultimate'
OSV='6.1 7601'
MODEL='P5-4/7142 (sunshine-home)'
NPROC='8'
CONFIG=15
NPROC=8
symbol=DELDIR='d:/msc.software/msc_nastran/20122/msc20122/nast/del' $(program default)
symbol=DEMODIR='d:/msc.software/msc_nastran/20122/msc20122/nast/demo' $(program default)
symbol=LM_NO_SNMP=1 $(d:/msc.software/msc_nastran/20122/conf/nast20122.rcf[5])
symbol=NASD_PATH=D:\MSC.Software\MSC_Nastran\20122\msc20122\dyna\win64 $(d:/msc.software/msc_nastran/20122/conf/nast20122.rcf[7])
symbol=NASM_PATH=D:\MSC.Software\MSC_Nastran\20122\msc20122\marc\tools $(d:/msc.software/msc_nastran/20122/conf/nast20122.rcf[6])
symbol=SSSALTERDIR='d:/msc.software/msc_nastran/20122/msc20122/nast/sssalter' $(program default)
symbol=TPLDIR='d:/msc.software/msc_nastran/20122/msc20122/nast/tpl' $(program default)
SDIR='d:/scratch/tst1d1.T2136_58'
DBS='./tst1d1'
SCR='no'
NEWDEL='d:/msc.software/msc_nastran/20122/msc20122/win64/SSS'
DEL='MSCDEF'
DML=MSCDEF
SDL=MSCDEF
AUTH='27500@sunshine-home'
AUTHQUE=20
MSGCAT='d:/msc.software/msc_nastran/20122/msc20122/win64/analysis.msg'
MSGDEST='f06'
NEWS='d:/msc.software/msc_nastran/20122/msc20122/nast/news.txt'
MSC_ISHELLPATH=d:\msc.software\msc_nastran\20122\msc20122\nast\tpl\1dstrain
MSC_JIDPATH=
PATH=d:\msc.software\msc_nastran\20122\msc20122\win64\lib;d:\msc.software\msc_nastran\20122\msc20122\win64;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\
SCA_SERVICE_CATALOG=d:\msc.software\msc_nastran\20122\msc20122\res\SCAServiceCatalog.xml
SCA_RESOURCE_DIR=d:\msc.software\msc_nastran\20122\msc20122\res
Cmd Line: D:\MSC.Software\MSC_Nastran\20122\msc20122\win64\nastran.exe JID=D:\MSC.Software\MSC_Nastran\20122\msc20122\nast\tpl\1dstrain\tst1d1.dat
Current Dir: D:\MSC.Software\MSC_Nastran\20122\msc20122\nast\tpl\1dstrain
Time Cmd: d:\msc.software\msc_nastran\20122\msc20122\win64\msctime
Executable: d:\msc.software\msc_nastran\20122\msc20122\win64\analysis.exe
Arch= Kywd: [Not specified]
MSC_MSG: stderr
FPE: yes
Current resource limits:
Physical memory: 8128 MB
Physical memory available: 6007 MB
Paging file size: 16254 MB
Paging file size available: 13885 MB
Virtual memory: 8388607 MB
Virtual memory available: 8388556 MB
System configuration:
Hostname: sunshine-home
Architecture: win64
Platform: Intel Windows 7 Ultimate 6.1 7601 (Windows Compute Cluster)
Model: P5-4/7142
Clock freq.: 7142 MHz
Number of CPUs: 8
Executable: standard
Raw model ID: 15
Config number: 15
Virtual memory: 16254 MB
Numeric format: 32-bit little-endian IEEE.
Bytes per word: 4
Disk block size: 512 bytes (128 words)
Remote shell cmd: "d:/msc.software/msc_nastran/20122/msc20122/win64/mscrmtcmd.exe" (Windows non-CCS nodes, UNIX)
<ccs_cmd> (Windows CCS nodes)
MSC.Nastran started Sun Aug 9 14:39:01 中国标准时间 2015
14:39:16 Beginning Analysis
SCA Kernel 7.3.119418 successfully initialized
BLAS/LAPACK .dll "d:\msc.software\msc_nastran\20122\msc20122\win64\mkl_core.dll" has been loaded.
BLAS/LAPACK .dll "d:\msc.software\msc_nastran\20122\msc20122\win64\mkl_intel_thread.dll" has been loaded.
BLAS/LAPACK .dll "d:\msc.software\msc_nastran\20122\msc20122\win64\mkl_rt.dll" has been loaded.
BLAS/LAPACK .dll "d:\msc.software\msc_nastran\20122\msc20122\win64\MSCblas.dll" has been loaded.
14:39:17 MSC Authorization Information - System Attributes (1004, 0)
14:39:17 -----------------------------------------------------------
Date: Sun Aug 09 14:39:17 2015
MSC Id: 60a44c341de5 (ethernet) (Intel)
Hostname: sunshine-home (user sunshine, display sunshine-home)
License files: 27500@sunshine-home
CEID: 4C341DE5-CA8252FA
User: sunshine
Display: sunshine-home
LAPI Version: LAPI 9.3.1-2109 (FLEXlm 11.9.0.0)
* * MSC Customer Entitlement ID * *
* * 4C341DE5-CA8252FA * *
14:39:17 MSC Authorization Information - Checkout Successful (1016, 0)
14:39:17 -------------------------------------------------------------
14:39:17 Acquired 1 license for MSC.Nastran from license server on host sunshine-home
Beginning bulk data processing using the IFPStar component.
For more information on IFPStar, please see KB article KB8019200
on our support pages, at http://simcompanion.mscsoftware.com.
14:39:18 80 records read from JID file "d:/msc.software/msc_nastran/20122/msc20122/nast/tpl/1dstrain/tst1d1.dat"
Processing of bulk data entries is complete.
14:39:18 Analysis started.
14:39:18 Geometry access/verification to CAD part initiated (if needed).
14:39:18 Geometry access/verification to CAD part successfully completed (if needed).
14:39:18 Finite element model generation started.
14:39:18 Finite element model generated 92 degrees of freedom.
14:39:18 Finite element model generation successfully completed.
14:39:18 Application of Loads and Boundary Conditions to the finite element model started.
14:39:18 Application of Loads and Boundary Conditions to the finite element model successfully completed.
14:39:18 Solution of the system equations for linear statics started.
14:39:18 Solution of the system equations for linear statics successfully completed.
14:39:18 Linear static analysis completed.
14:39:18 20 records read from JID file "d:/msc.software/msc_nastran/20122/msc20122/nast/tpl/1dstrain/tst1d1.dat"
14:39:18 NSEXIT: EXIT(0)
14:39:18 Analysis complete 0
AssignProcessToJobObject failed, error code = 5.
Error message is "拒绝访问。".
Reported CPU times may be incomplete.
Real: 2.820 seconds ( 0:00:02.820)
User: 0.483 seconds ( 0:00:00.483)
Sys: 0.234 seconds ( 0:00:00.234)
MSC.Nastran finished Sun Aug 9 14:39:18 中国标准时间 2015
gogogozzy
我激活了windows7的administrator用户,并用其登录后,再次执行报错的任务文件,不再报拒绝访问错误,nastran最后顺利生成pch结果文件,F06文件中无fatal和warning信息。应该是用户权限问题,原因也不去深究了,能用就行。。。
2015年8月9日
