100分求论文一篇:体成形数值模拟中的模具型腔、网格生成及接触搜索的一致描述
浏览:332291 回答:3
寇淑清  杨慎华  黄良驹  傅沛福
摘 要:以三次B样条曲面描述为基础,对体成形数值模拟中的复杂模具型腔、锻件三维网格自动划分、锻件与模具接触的状态进行了一体化研究。利用B样条曲面的直观性、局部性、通用性和造型灵活性,构造了复杂模具型腔及锻件边界,提出了三维网格样条生成法、改进的分块样条生成法及接触判断区域层次搜索技术。
关键词:有限元;B样条;曲面描述;网格生成;接触搜索
分类号:TG376 文献标识码:A
文章编号:1002-378X(2001)01-0019-06
Compatible Description of Tool Surfaces, FEM Mesh Generation and Contact Search for Simulating Complicated Massive Forming
KOU Shu-qing(Institute of Rolling Forging Technology, Jilin University, Nanling Campus, Changchun 130025, China)
YANG Shen-hua(Institute of Rolling Forging Technology, Jilin University, Nanling Campus, Changchun 130025, China)
HUANG Liang-ju(Institute of Rolling Forging Technology, Jilin University, Nanling Campus, Changchun 130025, China)
FU Pei-fu(Institute of Rolling Forging Technology, Jilin University, Nanling Campus, Changchun 130025, China)
AbstractThe 3-D tool surface description together with the automatic 3-D meshing methods and the contact search is carried out for the FEM numerical simulation of complicated massive forming based on the cubic B-spline. The complex geometry for die-cavity and forging surface is described; the spline technique for 3-D mesh generation as well as piecewise mesh generation is proposed and the region-section search algo rithm is done for the advantages of B-spline such as visualization, localization, generalization, flexibility and adaptation for graphic model.
Keywords:finite element; B-spline; curved surface description; mesh generation; contact search
基金项目:国家“九五”科技攻关资助项目(96-A22-03-02)
作者简介:寇淑清(1962-),女,黑龙江肇源人,吉林大学副教授,工学博士。
作者单位:寇淑清(吉林大学南岭校区辊锻工艺研究所,吉林 长春 130025)
     杨慎华(吉林大学南岭校区辊锻工艺研究所,吉林 长春 130025)
     黄良驹(吉林大学南岭校区辊锻工艺研究所,吉林 长春 130025)
     傅沛福(吉林大学南岭校区辊锻工艺研究所,吉林 长春 130025)
参考文献:
[1]Walters J. Applieation of finite element method in forging an industry perspective[J ]. J. Mater. Proess. Teehnol., 1991,27:43~51.
[2]Kiuchi M, Hoshino M. Computer aided simulation of complex three dimensional extrusions[A]. Advanced Technology of Plasticity[C], 1990: 387~394.
[3]Keum Y T. Compatible description of tool surfaces and FEM meshes for analyzing sheet forming operations[J ]. Int. Num.Meth. Engr., 1990, 30:1471~1502.
[4]Boehm W, Fann G, Kahmann J. A survey of curve and surface methods in CAGD[J ]. CAGD, 1984(1):1~60.
[5]施法中.计算机辅助几何设计与非均匀有理B样条(CAGD&NURBS)[M].北京:北京航空航天大学出版社,1994.
[6]寇淑清.三维复杂锻造过程数值模拟及直齿轮冷精锻成形研究[D].长春:吉林工业大学辊锻工艺研究所,1998.
发布立即结帖给分!
JUJU
多谢楼上的楼上,还有什么好的都发上来吧,尤其是接触搜索方面的,谢谢!
2006年7月27日
admin
专家分是用来衡量会员的CAE专家水平,靠技术答疑来获得。为了保证专家级别的客观性和权威性,请不要以征集资料|论文|散分等方式去奖励他人专家分。
试想:如果某些会员的专家分可以很容易地得到,那么专家分还有何意义?
前期社区的功能还不是很完善,希望大家都能理解并支持现有的专家分制度,下一步社区将杜绝这种现象的发生。
2006年7月26日
向阳
我这有,其他还要什么文章,在这儿发贴
2006年7月26日
