双线性弹塑性模型(五)
2021年7月3日 07:12浏览:3147 评论:1 收藏:1
本节内容为多杆结构的弹塑性有限元计算。
对于弹塑性材料, ,其中
含多个杆单元的结构,需要分别判断每个单元的弹塑性状态,确定是 或者 参与计算。
[算例]
如图所示,两个并联的杆,一段固定,另一端另一端施加轴向力P。荷载逐渐增加到 ,然后逐渐卸载至0。杆一。
杆二。
import matplotlib.pyplot as plt
import numpy as np
import numpy as np
import harden
E1 = 10000; H1 = 1111.11; sYield1 = 5
E2 = 5000; H2 = 555.55; sYield2 = 7.5
Et1 = 1000; Et2 = 500
mp1 = [E1, H1, sYield1];
mp2 = [E2, H2, sYield2];
nStress1 = 0; nAlpha1=0; neps1 = 0; eps_new1=0;
nStress2 = 0; nAlpha2=0; neps2 = 0; eps_new2=0;
A1 = 0.75; L1 = 100;
A2 = 1.25; L2 = 100;
tol = 1.0E-5; u = 0
RES = 0
nincr = 0
max_iter = 20
Load =[0,1,2,3,4,5,6,7,8,9,10,11,12,13,
14,15,14,13,12,11,10,9,8,7,6,5,4,3,2,1,0]
N = len(Load)
flag1 = 0; flag2 = 0
X = np.zeros( (N) )
Y1 = np.zeros( (N) )
Y2 = np.zeros( (N) )
for i in range(N):
nincr += 1
print('第{}增量步:' .format(nincr) )
P = Load[i]
RES = P - nStress1 * A1 - nStress2 * A2
du = 0
niter = 0
conv = 2e12
print('迭代步 位移 不平衡力 收敛参数')
while ( conv > tol and niter < max_iter ):
niter += 1
Eep1 = E1; Eep2 = E2
if flag1 == 1:
Eep1 = Et1
if flag2 == 1:
Eep2 = Et2
K = Eep1 * A1 / L1 + Eep2 * A2 / L2
delta_u = RES / K
du = du + delta_u
delta_eps = delta_u / L1
Stress_new1, Alpha_new1, eps_new1, flag1 = harden.KinematicHard1D(mp1,
delta_eps,nStress1,nAlpha1,neps1)
Stress_new2, Alpha_new2, eps_new2, flag2 = harden.KinematicHard1D(mp2,
delta_eps,nStress2,nAlpha2,neps2)
RES = P - Stress_new1*A1 - Stress_new2*A2
conv = RES**2 / (1 + P**2)
nStress1 = Stress_new1; nStress2 = Stress_new2
neps1 = eps_new1; neps2 = eps_new2
nAlpha1 = Alpha_new1; nAlpha2 = Alpha_new2
print(format(niter, '>3d'), format(u, '>20.12f'), format(nStress1, '>22.8f'),
format(nStress2, '>22.8f'), format(conv, '>22.14e'))
u = u + du
X[i] = u; Y1[i] = nStress1; Y2[i] = nStress2
print(X)
print(Y1)
print(Y2)
fig, axs = plt.subplots(1, 1, figsize=(7,12) )
axs.plot(X, Y1, label="M1", linewidth = 2, color = "deeppink",marker='o', markersize=6)
axs.plot(X, Y2, label="M1", linewidth = 2, color = "green",marker='o', markersize=6)
axs.set_xlabel('$ Displacement(mm) $', fontsize = 18)
axs.set_ylabel('$ Stress(MPa) $', fontsize = 18)
plt.ylim([-5,9])
plt.legend(['Bar1','Bar2'])
fig.savefig('./f428.png', dpi = 300) #保存图片
plt.show()
##### harden模块
import math
def Sgn(x):
if x > 0 :
return 1
elif x < 0 :
return -1
else :
return 0
def KinematicHard1D(MP,deps, stressN,alphaN, epsN):
E = MP[0]
H = MP[1]
Y0 = MP[2]
stress_tr = stressN + E*deps
eta_tr = stress_tr - alphaN
f_tr = math.fabs(eta_tr ) - Y0
if f_tr < 0:
stress = stress_tr
alpha = alphaN
ep = epsN
flag = 0 # 处于弹性状态
else:
dep = f_tr / ( E + H )
stress = stress_tr - Sgn(eta_tr) * E * dep
alpha = alphaN + Sgn(eta_tr) * H * dep
ep = epsN + dep
flag = 1 # 处于塑性状态
return stress, alpha, ep, flag
迭代路径
