Carsim_Run_out.txt
2021-03-16
下载
大小:255.28KB
该文件可以应用于caisim和其他软件联合仿真的是的输入输出
moving object 7 Moving object 7
HeadO_8 deg Heading angle Targets Heading angle, moving object 8 Moving object 8
HeadO_9 deg Heading angle Targets Heading angle, moving object 9 Moving object 9
ID_Event - ID number Database ID number of event ID of event
ID_Run - ID number Database ID number of run节选段落二:
ID of run
ID_S1_1 - ID number Sensor Detections Sensor 1 ID number, detect 1 Sensor 1, detect 1
ID_S1_10 - ID number Sensor Detections Sensor 1 ID number, detect 10 Sensor 1, detect 10
ID_S1_11 - ID number Sensor Detections Sensor 1 ID number, detect 11 Sensor 1, detect 11
ID_S1_12 - ID number Sensor节选段落三:
Wheel R1 rotation
Rot_R2 rev Rotation Wheels Wheel R2 rotation Wheel R2 rotation
Rot_TC rev Rotation Powertrain Trans input shaft rotation Transmission input shaft
R_AV_TC - Dimensionless ratio Powertrain TC output/input speed ratio TC output/input speed
R_M_TC - Dimensionless ratio Powertrain TC out
ID of run
Wheel R1 rotation
