关键字-Damping.pdf
2021-09-16 下载:13
下载
大小:164.26KB
关键字_damping
继续更新关键字
需要该关键字全文留言(是单个关键字哦)
The requested damping is applied
only to the parts in the set. If PSID = 0, the
damping is applied to all parts except those
referred to by other.
*DAMPING_FREQUENCY_RANGE cards.
(零件集 ID。需求阻尼仅应用于零件集中的
零件。如果 PSID=0,阻尼应用于*阻尼_频
率_范围卡片提及的部件之外的所有部件。)
节选段落二:
Remarks:(附注)
This feature provides approximately constant damping (i.e. frequency-independent)
over a range of frequencies Flow < F < Fhigh. It is intended for small damping ratios
(e.g. < 0.05) and frequency rang- es such that Fhigh/ Flow is in the range 10-300.
节选段落三:
The
drawback to this method of damping is that it re- duces the dynamic stiffness of the
A
新图章
