KEYWORD.pdf
2022-07-28 评论:1 下载:1
下载
大小:9.44MB
abaqus keywords
A brief description of the intended use of the keyword is listed at the top of each keyword section.
The Products field lists each of the products that support the keyword. Keywords that are at least
partially supported in Abaqus/CAE include Abaqus/CAE in the list of products.
节选段落二:
The user interface in
Abaqus/CAE does not necessarily support all optional parameters for each supported keyword.
The Type field indicates whether the keyword appears in the model or history data portion of the input
file.
节选段落三:
The Abaqus/CAE field indicates where within Abaqus/CAE you can locate the user interface related
to the keyword.
(1条)
