abaqus-tutorial-9-ball-plate-impact.pdf
ball imact
© TECHNIA Simulation Centre of Excellence | info@technia.com | www.technia.com/simulation Page 1
TUTORIAL 9 (ADVANCED):
BALL TO PLATE IMPACT WITH ELEMENT
DELETION
© TECHNIA Simulation Centre of Excellence | info@technia.com | www.technia.com/simulation Page 2
Learning Objective
• Define a ductile节选段落二:
An element deletion criterion is defined and therefore the plate ruptures and allows the
ball to pass through.
© TECHNIA Simulation Centre of Excellence | info@technia.com | www.technia.com/simulation Page 3
Pre-Processing
• Import the part geometry – Tutorial 9.sat
• Define the material properties节选段落三:
o Ball
▪ Modulus: 210,000 MPa
▪ Poisson’s: 0.3
▪ Density: 7.8e-9 Tonnes/mm3
o Plate
▪ Modulus: 70,000 MPa
▪ Poisson’s: 0.3
▪ Density: 2.5e-9 Tonne/mm3
▪ Plastic Properties:
Yield Stress Plastic Strain
100 0
110 0.05
In addition to the elastic and plastic properties for the plate, we need to define
DELETION
Learning Objective
Pre-Processing
o Ball
▪ Poisson’s: 0.3
o Plate
▪ Poisson’s: 0.3
100 0
110 0.05
