10-1.txt
2022-10-10
下载
大小:31.24KB
contour integral
*surface, type=ELEMENT, name=ASSEMBLY_SURF-2
*surface, type=ELEMENT, name=ASSEMBLY_SURF-1
*material, name=MATERIAL-1
*elastic
*solidsection, elset="ASSEMBLY_new rock-1_SET-6", material=MATERIAL-1
*boundary
*boundary
*boundary
*节选段落二:
*dsload
*output, field, variable=PRESELECT
*output, history, frequency=0
*endstep
*boundary
*boundary
*boundary
*Step, name=Step-1, nlgeom=NO
*static
*contourintegral, crackname=H-OUTPUT-1_CRACK-1, type=KFACTORS, direction=KII0, contours=1, cracktipnodes
***NOTE: THE节选段落三:
O N T O U R S
NAME NODE SET
H-OUTPUT-1_CRACK-1
-21- K1: 1.3088E+10
K2: 7.4378E+09
K3: -1.6205E+10
KII0 DIRECTION (DEG): -45.18
*elastic
*boundary
*boundary
*boundary
*节选段落二:
*dsload
*endstep
*boundary
*boundary
*boundary
*static
***NOTE: THE节选段落三:
O N T O U R S
NAME NODE SET
H-OUTPUT-1_CRACK-1
-21- K1: 1.3088E+10
K2: 7.4378E+09
K3: -1.6205E+10
