tosca1.pdf
2022-11-13
下载
大小:1.10MB
tosca优化
during the optimization
节选段落二:
Press OK
Step 7 - Saving TOSCA Structure parameter file
The TOSCA Structure parameter file contains
ASCII commands which define all settings for the
optimization task. 1 1. Right click on the Output item
2. Select Update. The parameter file for TOSCA
Structure is written at this point.
节选段落三:
TOSCA will also run in this directory
T
A SA v.13.x Optimization with A SA N N
BE A CAE Systems S.A. 13
4. Start Optimization
1. Right click on the RUN Task item under
START_OPTIMIZATION
2. Select Update
TOSCA Structure starts in background. Wait until it
finishes.
5.
