造船英语口语教材.doc
1. 验船师什么时候来?When will the surveyors be here?
2. 都到齐了,开始吧。Everyone is here. Let’s begin.
3. 你们的检验员看过没有?有什么问题?Have your inspectors checked it? Any problems?
4. 检验员已经看过了,没有问题。The inspectors have checked it. No problem.
5. 只有一些小毛病。There are only several problems.
6. 焊脚尺寸不均匀,需修补。The welding is uneven and needs some remedy.
7. 这管子需喷射除锈。The pipe needs abrasive blasting.
8. 这里有气孔,需挖掉后再修补。There is an air hole here. Please scrape it and have a repair.
9. 焊脚尺寸太大,需补焊打磨。The welding is too thick and needs welding and grinding.
10. 这里有咬口,需补焊。There is a seizing here. Reweld it please.
11. 管子内部需打磨。The inside of the pipe needs grinding.
12. 管子外部需打磨除锈。The outside of the pipe needs grinding and cleaning.
13. 这里不能用火焰切割。Here isn’t a flame cutting.
14. 这里衬垫焊。Please weld with backing.
15. 十字接头焊脚处需打磨。The welding of cruciform joint needs grinding.
16. 这里有焊接裂缝。Here is a weld crack.
17. 这个层状撕裂需修补。The lamellar tearing needs grinding and welding.
18. 去掉这个焊瘤,再补焊。Please scrape the overlap and reweld.
19. 这里有熔渣,去掉后再补焊。There is a slag inclusion, please scrape and reweld it.
20. 这个裂缝是冷裂缝,修补一下。The weld crack is cold crack, please grind and weld.
CHARGE
CONC
CONCERNING
CO
COMPANY
COND
CONDITION
CHRTR
CHARTER
DIV
DIVISION
DO
DRYDOCKING
DWT
DEAD WEIGHT
DTD/DD
DATED
DISCH/DISCHG
DISCHARGE/DISCHARGING
DTL
DETAIL
DPT/DEPT
DEPARTMENT
DLY
DELAY
DLVERY
DELIVERY
DLVR
DELIVER
DIFF
DIFFERENCE
DIR
DIRECTOR
DIRTLY
DIRECTLY
DOC
